Hello...
13:57:08
26.10.2007
26.10.2007
Matsoft
4
13:56:50
26.10.2007
26.10.2007
Matsoft
3
13:56:32
26.10.2007
26.10.2007
Matsoft
2
13:56:16
26.10.2007
26.10.2007
Matsoft
1
13:53:18
26.10.2007
26.10.2007
Matsoft
-> tony_: no deep rust... only some little spaces like scratched color... moment.. I will find photos... color is not good. I see the car. and maybe I will buy it... because the contition is realy good...
13:49:30
26.10.2007
26.10.2007
tony_
Hello..can you send me some pictures with the car? and the rust areas?
Thanks for now...
Thanks for now...
13:34:11
26.10.2007
26.10.2007
Matsoft
-> tina: ooo noooo. mileage is 67000km
13:32:33
26.10.2007
26.10.2007
tina
-> Matsoft: 67000km it is really far away, isn´t it:-)
00:17:57
26.10.2007
26.10.2007
Matsoft
-> tony_: I know about very good 105 - first type... only 67000km, very minor rust. Drivable, STK (Technical Exam/Control till March 2009) and is only for 4000CZK.
20:47:22
25.10.2007
25.10.2007
tony_
i would like a saloon (4 doors)..... :( I don`t like coupe.....sorry
Anything else?
Anything else?
11:38:57
25.10.2007
25.10.2007
ventYl
-> tony_: For example Tom.t here on virt sells Skoda Rapid shell (skoda-virt.cz/cz/.../). It's little different from Skoda 120 new type shell. He says that body shell is in good condition. His price is 2500 SKK ( = cca 2200 CZK). Shell is now located in east slovakia.
This shell is almost compatible with your engine, axles, but it's recommended to mount wide front and rear axle (Skoda new type) into this shell else your car will look like train (wide shell, narrow axles) and won't have good stability.
22:22:16
24.10.2007
24.10.2007
tony_
Hello.....did you had any time to look after a shell? Did you looked after some prices?
Thank and hope to hear from you...
12:10:01
21.10.2007
21.10.2007
Matsoft
-> tony_: 135 is no more for sale as new.... you can buy only old... both types 742.135-skoda or 781.135-favorit.
price between 1000 and 5000CZK - higher price for 742 type
11:37:08
21.10.2007
21.10.2007
tony_
Can anyone estimate the price of an S135 engine set? or a catalogue of prices for these type of engine?
11:24:15
21.10.2007
21.10.2007
tony_
Thanks i would be greatfull to you if you could do this thing for me....
I would really apreciate that
11:22:14
21.10.2007
21.10.2007
Matsoft
-> tony_: not now, but maybe on wednesday evening.... I am going to look to SKODA used cars shop
11:20:26
21.10.2007
21.10.2007
tony_
Does any of you know a shell or a car for a lower price ?
11:19:25
21.10.2007
21.10.2007
tony_
in Romania....if it`s in Romania there will be no problem....I don`t know your paperwork
11:18:02
21.10.2007
21.10.2007
Matsoft
-> tony_: yes... very easy... Export is not problem.... but to make it legal in BG it will be harder....
11:16:28
21.10.2007
21.10.2007
tony_
what paper work does my friend need to buy and to export such thing? Does anyone know?
11:14:27
21.10.2007
21.10.2007
Matsoft
-> tony_: it depends on luck :-D
sometimes you buy great car for very low price, sometimes for very high.... so price between 5000 and 20000 CZK
11:12:17
21.10.2007
21.10.2007
tony_
can you estimate a price?
11:02:20
21.10.2007
21.10.2007
ventYl
In CZ and SK it's not a big problem, but it's problem to find body shell in good condition which is for sale. Another problem is that I don't know if is possible to export such body shell (in SK the only identification mark of car is VIN typed in front par of car under front hood).
But your friend must (should) get same type of bodyshell as he has now. If he find body shell of newer type (1984 and newer) his current axles (1982) are too narrow for wider body shell and car will be more unstable while steering. To the newer body he should mount also new wider front axle with new steering type and wider rear axle.
10:52:26
21.10.2007
21.10.2007
tony_
i`ve talked to my friend and he asked me if i know somewhere he could find a body shell in better condition (without much rust on it) and unhitten...
Can you tell me something about this thing?
Thanks a lot for your help
10:18:25
21.10.2007
21.10.2007
ventYl
Most spare parts for 135 engine are available, because this engine is nearly identical to engine of Favorit 135. There are some minor differences, but in my opinion they wouldn't be relevant for buying spare parts.
Deep battery hole is relevant only if you mount rear axle with dry half-axles (newer type). 5-speed gearbox can be mounted with both types of axles (wet half-axles, dry half-axles) but if gearbox was previously mounted with dry type, some changes will be necessary to mount it on wet axle. Of course, if you try to mount 5-speed gearbox with dry axle, you also need this complete rear axle and chassis beam for 5-speed gearbox with mount points for dry rear axle.
09:56:39
21.10.2007
21.10.2007
tony_
spare parts for 135 engine .
for the other problem my question was if the gearbox and all it`s components can be fitted because the car has the big space for the battery....
09:27:37
21.10.2007
21.10.2007
ventYl
Is not possible to mount 5-speed gearbox into Skoda made before 1983, because this bodyshell has some chassis beams placed in way which collides with larger 5-speed gearbox.
If you want place 5-speed gearbox in this car you must change this beam. Some bodyshells made between 1983-1984 (sept. 1982 - sept. 1983) are capable of mounting 5-speed gearbox, some not (in this year Skoda migrated from production of classic Skoda 105/120 to production of modernized Skoda 105/120). All bodyshells made after 1984 (~ sept. 1983) should be capable of mounting 5-speed gearbox (only if bodyshell was made far before completation of car and waited some time in deposit).
Before mounting 5-speed gearbox is sometimes need to change fuel tank from newer Skoda (not necessarily from 5-speed Skoda). It applies mainly to cars made before 1986 where sometimes was mounted fuel tank found somewhere laid ;) In car made before 1984 you must change tank always.
Other changes required for mounting 5-speed gearbox in place of 4-speed qearbox are similar to newer cars (after 1984, shortly marked as M).
Spare parts for which engine? 120LS or 135?
23:23:45
20.10.2007
20.10.2007
tony_
I have a question for a friend of mine who has an 82 Skoda 120 L...
Can he mount on his car the 5 speed gearbox?
What changes has to do?
20:54:13
20.10.2007
20.10.2007
tony_
spare parts for the engine is possible to find?
the engine as i saw had a classic 32 EDSR.....
What can go wrong in these engines?
is the alloy cylinder head better than the old one?
20:47:49
20.10.2007
20.10.2007
ventYl
Answer to your older question:
There was an 135 fuel injection engine made by Skoda. It was sold as Skoda 135GLi (sedan) or Skoda 135RiC (coupe). But was manufactured only few thousands of these cars and there are nearly none spare parts available for this type of engine.
Maybe you'll be able to buy second-hand injection unit and controlling unit (it's Bendix-Renix unit from Renault R-19 maybe), but I don't know, if Renault's software in Renix (controlling unit) is suitable for 135 engine. Also there is really pool knowledge about lambda sensor and other equipment of fuel-injected Skoda 135 and nearly everything is TOTALY unobtainable.
20:42:01
20.10.2007
20.10.2007
ventYl
Engine S742.135 (Skoda 135) has 43kW (approx. 58 HP). Your engine S742.12X (Skoda 120LS) has 40,5kW (approx 55 HP).
The trouble is, that Skoda 135 engine has different exhaust and intake port (136 has 8-channel ports, 120LS has 5-channel ports). These ports are hardly obtainable in CZ and SK because of number of manufactured vehicles with these engines.
In my opinion, you shuld stay with your LS engine. If this engine is in good condition, it's power output is comparable to 135 engine.
20:14:45
20.10.2007
20.10.2007
tony_
LS....sorry
20:13:51
20.10.2007
20.10.2007
tony_
Hello again kind people....I have a new question for you :( . Does it worth to put a Skoda 135 engine on my 120 GLS Skoda?
How many horse power does it have the 135 engine?
Some benefits? What is improved on it?
Thankyou again....
Thankyou again....
23:57:05
05.10.2007
05.10.2007
23:56:52
05.10.2007
05.10.2007
23:56:36
05.10.2007
05.10.2007
23:48:55
05.10.2007
05.10.2007
-> tony_: But numbers in Nwkt's link are only numbers of forms from pruduction of cylinder head.
You can detect type of head only by color of Skoda logo.
105 - black
120 - yellow
120LS - green
130 - brown
If you take cylinder head from cylinder blok, you can detect head by diametry of intake and exhaust valve, or by design of combusion space.
some types of engines has different position of cylinder. OO OO or OOOO
OK?
105 - black
120 - yellow
120LS - green
130 - brown
OK?
23:02:12
05.10.2007
05.10.2007
tony_
Thanx and sorry for the offtoppic but i don`t know your language.
23:01:02
05.10.2007
05.10.2007
-> tony_: Some numbers are in this toppic skoda-virt.cz/cz/.../6510
6-cisla-hlav
22:58:52
05.10.2007
05.10.2007
tony_
Can someone provide me some serial numbers from the cylinder head for the different types of cylinder heads? (105,120 L, 120Ls, GLS, 130)
Thanks again...
Thanks again...
22:53:31
05.10.2007
05.10.2007
tony_
Thanks...
22:52:41
05.10.2007
05.10.2007
/1 = 105
/2 = 120
/3 = 120 - chladírenská jednotka / v podstatě se jedná o stacionární motor určený k pohonu chladících agregátů v např. kamionech/ V čem se tento blok liší od bloku zn.3/ se mi nepodařilo zjistit.
/4 = 110 R/LS
/5 = 11O L
/6 = 120 Garde,Rapid
/7 = 130
/8 = 100
/9 = 120 LS
/2 = 120
/4 = 110 R/LS
/5 = 11O L
/7 = 130
/8 = 100
/9 = 120 LS
22:49:52
05.10.2007
05.10.2007
tony_
Hello again.What tipe of engine has /9*? or something like this? Can someone tell me?
10:10:32
03.10.2007
03.10.2007
tony_
Hello kind people i have a new question for you....
Does the gas injection improve higher performances on an 120 engine? is it mountable and what price is a second hand one....
07:34:30
20.09.2007
20.09.2007
petas
-> tony_: There are two types of S120 exhausts. One is like a paper prized about 350CZK and second is more solid, heavier and more durable. Costs about 450CZK and lasts about 2x longer than the cheaper one. If you consider post tax, i would recommend the more expensive one.
00:18:46
20.09.2007
20.09.2007
-> tony_: first column is weight of parcel, second column is price at CZK
16:52:27
19.09.2007
19.09.2007
tony_
yes that is what i want....
Can someone tell me aproximatley the post taxes?
16:45:20
19.09.2007
19.09.2007
Tuxik
16:42:18
19.09.2007
19.09.2007
tony_
by exhaust i mean the pipe that lets out the gases that the engine burned.....
12:19:00
19.09.2007
19.09.2007
Tuxik
-> tony_: price of second manufactured exhaust is approx. 350CZK
