155 příspěvků (zobrazeno 101 až 150) od 12.09.2007 do 04.02.2008, založil/a tony_
11:53:34 19.09.2007
tony_
Hello people...me again....can someone tell me the price of a exhaust? mine has some holes in it and it sounds auful ....
And the post how much is it aproximatley?
Thanx
07:36:13 18.09.2007
petas
-> Gryzly: ajo ... ja si na tenhle vyraz nemohl vzpomenout
-> tony_: and if the distributor is turned other way, you should connect the first cable to the hole where the thumb is pointing to (but it is the shortest cable, so it may be too short), or take out the distributor and put it back in the right rotation.
19:22:38 17.09.2007
petas
-> tony_: ignition order is 1-3-4-2. When you turn the engine, so 1st piston is at the top, thumb of the distributor should be about 2.5 o' clock. There should be plugged cable to the 1st candle.
17:39:06 17.09.2007
Tuxik
-> tony_: first cylinder is located near distributor
17:35:45 17.09.2007
tony_
I know it is a stupid question but please help me on these one to....
Which is the ingition order and where is located the 1-st cylinder (at water pump or at the cluth)....
Thank you
13:03:55 17.09.2007
Matsoft
-> tony_: it is hard to say. you can buy S120 in very good condition for 3500CZK, but also for 30000CZK.
12:18:26 17.09.2007
tony_
Can someone tell me the price of a good Skoda 120 (bodywork) the mechanical part i will do it myself.
Aproximatley.....
Thanx
08:51:33 17.09.2007
Matsoft
-> tony_: I recomend type from Rapid.... (whole gearbox+axles). the best from this type is gearbox from 120LX or Rapid RiC, but due to manufactured pieces it is almost impossible to buy.
00:40:49 17.09.2007
tony_
what type do you recomand?
00:40:00 17.09.2007
Matsoft
-> tony_: ok, so no problem with 5speed gearbox....
00:37:29 17.09.2007
tony_
it`s a 86 LS Skoda 120
00:35:55 17.09.2007
Matsoft
-> tony_: btw. what type and from which year you have?
00:33:42 17.09.2007
-> Matsoft: A co ma typek za karu? eMko nebo Uzofku? Aby tam ten 5q narval
00:32:08 17.09.2007
Matsoft
-> tony_: new 5speed gearbox is impossible to buy. but old (taken from car) costs 1000-3500CZK - depends on type, condition .....
00:27:06 17.09.2007
tony_
Hello again..... me bothering you again :)......can someone tell me the price of a 5 speed gearbox and if is recomanded?
Thank you
-> everybody ukažte mu fotku kde je ten pojistný ventil na olejovém čerpadle. Já takovou fotku nemám.
21:45:56 13.09.2007
tony_
in the first picture is the gas pump...
21:43:53 13.09.2007
tony_
I mean the oil pump , the 2 sprockets are weared(there is a large gap between the sprocket and the cap)...
Another question...if I may.... where is located the relief valve on an engine like in the pictures?
Thank you
16:40:58 13.09.2007
If you have problem with oil bulb control, then you can check if you havent dirty strainer on oil pump.
If its clean its posible your crank-shaft bearing wear, and need regrinding and new crank brass
-> tony_: when you click on ID link under our nick names you will get our email address...
so if you have some problem with your car you could use this forum to ask as and if somebody will know answer, then will answer...so just ask..
10:14:53 13.09.2007
tony_
can someone than give me an e-mai adress please? . Thank you for understanding...
10:13:51 13.09.2007
aDAm
-> bitmap: mno i use msn and jabber instant messenger...ICQ is shit IM...
10:06:55 13.09.2007
bitmap - zrušená registrace
-> tony_: I,m afraid that noone here use Yahoo or MSN. Everyone in Czech run on ICQ unfortunately, so I'm afraid you will have to use an e-mail.
09:45:53 13.09.2007
tony_
can someone please give me a yahoo or MSN id to talk to him? Please i don`t wanna be off topic ....
Thankyou for all ...
09:40:22 13.09.2007
Podle mě chce sadu na go motoru 120LS , rozvody a olejové čerpadlo
09:34:24 13.09.2007
Valec je prece cyllinder :)
09:04:01 13.09.2007
tony_
I am sorry about the off topic.... , I really don`t know your language , i hope you will understand me....
07:41:31 13.09.2007
-> tony_: Hi. little bit off topic.
My colleague with husband, is now in Romania. They are on holiday at Retezat and camping near the Bucura Lake. At sunday they will came back.
07:28:15 13.09.2007
-> Tuxik: já myslím že mu problikává policajt a tak myslí že má blbej oil pump. a zatím má vylágrovanou kliku.
01:01:33 13.09.2007
Tuxik
-> Bagrr: co ja vim treba do toho leje naftu :-)
01:00:01 13.09.2007
Bagrr- máma mele Emu
-> Tuxik: Všechny vyjmenované hmoty snad ale nejdou přes paliovou pumpu u eLSa, teda alespoň u nás
00:59:08 13.09.2007
Tuxik
-> Bagrr: no ono totiz oil == olej nebo taky nafta, ropa ci petrolej... takze buh vi :)
00:58:04 13.09.2007
-> Tuxik: Já teda anglicky neumim, ale tohle mě praštilo do očí
-> Bagrr: nevim no :) alespon si procvicim anglictinu
00:55:57 13.09.2007
-> Tuxik: No ví bůh proč by chtěl olejový čerpadlo, ssadu pístů atd... Já bnapř taky koupil nový ozubený kolečka pro jistotu...
00:55:51 13.09.2007
Tuxik
-> tony_: did you mean oil pump or fuel pump ? oil pump is two sprockets and its really unbreakable :)
00:53:42 13.09.2007
Tuxik
-> Bagrr: nuze dobra ale olejovy cerpadlo je neporuchovy :-) jeste jsem neslysel ze by se poskodilo, teda pokud nekdo mezi zoubky nesypal maticky :)
00:52:59 13.09.2007
-> Tuxik: Eee proč myslim že pdo pojmem oil myslí olejová a ne benzínová. To by napsal fuel ne?
00:50:57 13.09.2007
Tuxik
-> tony_: the set of pistons, tonques and rolls (i dont know how to translate "valec" :-)) costs about 2684CZK, chain+sprockets set costs about 500CZK, but there is a problem with quality of secondary manufactured parts... :-(
oil pump can be repaired - you need membrane and ventils, its no problem to buy - it costs about 100CZK
very big problem is transport of parts to Romaina - maybe some of members from this site can go near you - for example to holiday, its perfect chance to transport some of parts :) transporting by post may be quite expensive
