S136R (šedý II)- mam ho od roku 2000; dilci renovace a upgrady: 2004, 2009, 2015-2017
cilovy stav je uplne renovovane auto, pri vyuziti drobnych uprav motoru, podvozku a elektriky, vzhledove jen malo odlisne od originalu.
Rad si obcas projedu nejaky horsky prusmyk nebo vyjdeu na kopec (pokud mozno nad 2500m), maly seznam:
Alpy:
1 GrossGlockner - Hochtor 2550m (Rakousko, 2006, 2019)
2 Passo Resia 1508m (Italie, 2007, 2010, 2011, 2019, 2021)
3 Passo Stelvio 2750m (Italie, 2007, 2009, 2010, 2011, 2019, 2021, 2025)
4 Passo Gavia 2640m (Italie, 2007, 2019)
5 Simplonpass 2005m (Svycarsko-Italie, 2007, 2011)
6 Furkapass 2436m (Svycarsko, 2007)
7 Oberalppass 2046m (Svycarsko, 2007)
8 Passo piccolo san Bernardo 2188m (Francie, 2008, 2010, 2011)
9 Passo grande san Bernardo 2423m (Svycarsko-Francie, 2010, 2011)
10 Col de'l Iseran 2770m (Francie, 2008, 2010)
11 Col du Galibier 2645m (Francie, 2008,2009)
12 Col du Vars 2111m (Francie, 2008, 2011, 2021, 2024 (2×))
13 Cima de la Bonette 2802m (Francie, 2008, 2011, 2021, 2025)
14 Passo Rombo 2503m (Rakousko,Italie, 2009)
15 Col de'l Izoard 2344m (Francie, 2009, 2021, 2025)
16 Umbrailpass 2503m (Italie-Svycarsko, 2010)
17 Passo dello Splungo 2118m (Italie-Svycarsko, 2010, 2011)
18 Nufenenpass 2478m (Svycarsko, 2010)
19 Col de la Croix du Fer 2068m (Francie, 2010)
20 Passo S. Bernardino 2065m (Svycarsko, 2011)
21 Passo Torre di Fraele 1800m (Italie, 2011)
22 Passo di Foscagno 2291m (Italie, 2011)
23 Passo Bernina 2328m (Svycarsko, 2011)
24 Livigno Pass 2315m (Italie-Svycarsko, 2011)
25 Montgenevre 1854m (Francie, 2011, 2021, 2024)
26 Passo Sella 2218m (Italie, 2019)
27 Passo Pordoi 2239m (talie, 2019)
28 Passo Falzarego 2105m (Italie, 2019)
29 Col d'Allos 2250m (Francie, 2021)
30 Colle della Maddalena/Col de Larche 1996m (Fr-It, 2021, 2024, 2025)
31 Col de la Cayolle 2326m (Francie, 2024)
32 Col de la Machine 1011m + Combe Laval (Francie, 2024)
33 Col Agnel 2744m (Fr-It, 2025)
34 Col de la Lombarde 2350m (Fr-It, 2025)
ToDo:
prio 1:
Alta via del sale (Italie)
prio 2:
Flüela Pass (Svycarsko, 2383 m)
Albula Pass (Svycarsko, 2312 m)
Grimsel Pass (Svycarsko, 2164 m)
Ostatni:
1 Veleta 2600m (az nahoru se vyjet neda) (Sierra Nevada, Spanelsko, 2010)
2 Pas de La Casa 2400m (Pyreneje, Andorra, 2009)
3 Col d'Aspin 1489m (Pyreneje, Francie, 2011)
4 Col du Tourmalet 2115m (Pyreneje, Francie, 2011)
5 Port de Boucharo 2270m (Pyreneje, Francie-Spanelsko, 2011) az nahoru vyjet nejde, zavalena cesta
6 Col du Soulor 1474m (Pyrenje, Francie, 2011)
7 Col du Aubisque 1709m (Pyreneje, Francie, 2011)
8 Col du Pourtalet 1794m (Pyreneje, Francie-Spanelsko, 2011)
9 Transfăgărășan 2042m (Făgărăș, Rumunsko, 2022, 2023)
10 Pasul Urdele 2145m (Capatanei, Rumunsko, 2022)
ToDo:
Pikes Peak (USA-CO, 4301 m) :D
Stav:
-> Pohon
--> Motor 1.5 (druha verze od MEXu 2009 po repasi 2015), olejovy chladic (MOCAL, 115mm 34 rad.) plus termostat
--> spojka SACHS s lamelou z TAZ1500 (109-150111, 441 270 532 529).
--> ventilator dochlazovani SPAL, trochu mne zklamal, ale nejak to chladi
--> Karburator revize C:
----> komora 25/28 udelana ze zakladu 23/27.
----> hlavni systemy: I st. 140/180, II. st. 160/140. II. st.
----> prechod/volnobeh: I. st. 50, II. st. 70
----> viko SEDR T613, ventil 2mm
----> sytic (tlumitko, tycka, kluisa) dle originalu SEDR T613, tryska 145
--> mereni teploty oleje a vody ridici jednotkou (presnost +-1 st.), sensor domaci vyroby s termistorem EPCOS (kalibrovano)
--> indikace tlaku oleje (VDO set - snimac 10bar + klasicky indikacni budik, presnost +- bota)
--> lpg na hrani a levnejsi jezdeni (1998,2009,2020)
--> upravene sani s implementovanou upravenou starsi verzi mixu pro fel 1.3 (viz. foto)
---> snizeni zastavbove vysky
---> lepsi provoz na beno a hlavne bez der, zpusobenych virenim za puvodnim mixem
---> vestaven delsi vzduchovy filtr z Fiatu Doblo 1.4JTD? (3C1-18900, C 1189 (Mann) )
--> vestaveny modul pro prubezne mereni bohatosti sirokopasmovou LS (Bosh LSU4.2)
--> elektronicka ridici jednotka zapalovani BTZ-III (2007)
-> Podvozek
2004:
--> nova zadni naprava, vyztuzena nova podelna ramena, nova sikma ramena, nove silentbloky, nova pricka
2008:
--> nove kloubove hridele
2009:
--> Predni naprava s chlazenymi kotouci (Saky) a pruzinami 260mm (od PJ) (2009)
2020:
--> Vymena kotoucu - opet za Sakyho typ (upravce wena), vyreseneo zahadne mlaceni
--> Vymena naboju a prednich lozisek
2021:
--> Vymena zadni napravy
--->Osazena puvodni ramena sikma i podelna a pricka (demontovano 2004), podelna vyztuzena, pricka ovarena
--->Nove tlumice (Monroe z sedeho I po 21 letech demontovany)
--->Loziska 21306 (+spacer) a NU205
--->Hridele Kalmar
--->Nove silentbloky
2022:
--> Instalovany unasece kol od paja120
-> vicemene nova prevodovka 5q/3.9 a prislusenstvi (2004, 2009, 2015)
--> servis a serizeni (Wena, 5/2024)
-> Elektro
--> Zastavba BlueTooth gatewaye, k jednotce je mozno se pripojit pres BT z notebooku nebo telefonu (SPP)
--> Elektronizovany pristrojovy stit (krom tachometru - je v planu) (2010)
--> Renovace/vymena predni casti svazku
--> Predratovani hlavnich napajecich vodicu
--> Pridavna pojistkova skrinka na baterii (pritomnost nejistenych dratu vedoucich vsude mozne mne stavala)
--> Doplneno silove jisteni sarteru a alternatoru
-> Karoserie
--> nove zadni okno tonovane na cca 50% nakovenim, bocni na 30% (2007)
--> vymenene predni blatniky (2004, 2016)
--> novy lak 1305 - barva + bezbarvy lak (2004)
--> novy lak 1305 - barva + bezbarvy lak (2017)
--> vymena stropnice (2017)
Poznamkovnik (naplne, spotrebni material, netypicke dily):
Maziva a jiné materiály:
- predni kola SKF LGWA 2
- zadni kola SKF LGWA 2
- svislaky Mogul A00
- vodni cerpadlo SKF LGHP 2
- homokinetaky Millers Hi Mol 20
- motor:
-- Millers Oils NANODRIVE - CFS 10W-60 NT+ (10/2024; 4/2023)
-- Lozisko v klice SKF LGHB 2
- prevodovka:
-- Castrol Syntrans Transaxle 75W-90 (Novy od: 2024, 2017), doplneno 6/2023 2dl
- chladici kapalina G12+
- brzdovka DOT 4 ATE 200 (5/2025)
- brzdy predek - Ferodo Ds2500 /* "Renovak" */
- brzdy zadek - Renovak beral
- vzduchovy filtr (longbox) MANN C 1189
- spojkova lamela TAZ1500 (109-150111, 441 270 532 529)
- spojkove lozisko SACHS (02) 3151 812 001
- chladic oleje MOCAL, 115mm 34 rad.
- termostat oleje MOCAL OT/2G
- ventilator dochlazovani vody VA02-AP70/LL-52A
- snimac tlaku oleje 443429021000 Tatra - snad ekvivalent VDO 360-081-030-004C
- indikator tlaku oleje VDO-350010014K
- snimac teploty oleje pro VDO indikátor - interní kalibrační označení 12
- civka Pertronix 60103 (0.3 Ohm, 2.6mH, 60kV)
- pneumatiky: Continental EcoContact 3 185/70 R13
- palivove hadice dle spec. SAE 30R9
/* - neaktualni -
motor:
-- Castrol Edge TITANIUM FST 10W-60 (6/2021)
-- snimac tlaku oleje VDO 360-023 (0-10bar) + indikator tlaku oleje VDO-350-108 (0-10bar, stupnice PSI) demontaz 6/2023
-- Karburator A: 23.5/26.5 I. st. 130/180 II. st. 160/140 - slouzi jako zalozni nouzovy
-- Karburator B: 26/28 mm z polotovaru 22/24. Puvodne I. st. 130/160 II. st. 155/140. (nasazuje bohate pak prilis chudne) Nalsedne II. st. 145/120. Prechodove/volnobezne trysky lehce zvetseny, prumer neznamy.
- Karburator D: komora 23/27 (T-613 bez uprav). I.st 130/180/50 2st. 155/140/60
Zadni naprava:
- vnitrni lozisko 22205 (zkraceny naboj u kloubu o 3mm)
Alpy:
ToDo:
prio 1:
prio 2:
Ostatni:
ToDo:
Stav:
-> Pohon
-> Podvozek
2004:
2008:
2009:
2020:
2021:
--->Hridele Kalmar
2022:
-> Elektro
-> Karoserie
- motor:
- prevodovka:
/* - neaktualni -
motor:
Zadni naprava:
COL/S136R - komentáře:
22:45:39
22.12.2005
22.12.2005
Max
-> COL: ta jednotka je zajímavá....seš husťák :-) V čem to programuješ ? Jo a jak je to velký rozměrově (ta jednotka) ?
22:45:05
22.12.2005
22.12.2005
Max
22:23:06
22.12.2005
22.12.2005
strucy
-> COL: zaujímavé
22:21:01
22.12.2005
22.12.2005
COL
Uploadnul jsem fotky RJ, ktera bude od jara ve zkusebnim provozu. Zatim bude ridit jen zapalovani, merit teplotu, orientacne lambdu, detekovat klepani apod. vyhledove se pocita s rozchozenim vstrikovani, podporuje MPi beno a SPi LPG.
22:20:19
22.12.2005
22.12.2005
COL
19:00:14
08.11.2005
08.11.2005
COL
-> Labros: me taky... :o/
18:55:29
08.11.2005
08.11.2005
Prostředí z druhý a třetí fotky znám, bude se mi po něm hrozně stýskat...
18:54:08
08.11.2005
08.11.2005
Paráda...
23:42:39
12.09.2005
12.09.2005
pekny rapid. a hadaj co sa mi na nom najviac paci :) no moja farba, skoda ze ja taku nemam (farbu) mam namiesanu len tak z luftu
14:02:04
29.07.2005
29.07.2005
Rapid135
prekrasnej kus
22:03:34
26.07.2005
26.07.2005
COL
-> kubina: tak vytahuj a fot, uz se ho nemuzu dockat... Co takhle novy bocni listy ty by nebyly?? :o)
08:25:29
22.07.2005
22.07.2005
-> COL: neda a neda
ne chapu to.
hele to plato ti necham za rekneme za 700.ja ho vytahnu a prohlidnu,nafotim a dohodnem se.
ne chapu to.
21:04:10
21.07.2005
21.07.2005
COL
800? poklicky budu potrebovat, dustojnou nahrazku se mi zatim nepovedlo vyvinout.
10:04:40
18.07.2005
18.07.2005
-> COL: jo to plato je funglovka,dokonce bys musel proriznout kozenku kvuli zadnim pasum....
radeji bych prvni variantu
17:02:42
17.07.2005
17.07.2005
COL
Za nove plato? No co treba 750,- bez poklicek?
14:56:17
15.07.2005
15.07.2005
-> COL: das za nove zadni plato 500kc a ty 3poklicky?
23:58:14
08.07.2005
08.07.2005
COL
-> jo, ta barva se mi libi.... Poklicky mam 3, u čtvrý se mi ulomily dvě packy. Počítám, že vyrobím něco místo nich... Shánim spíš meteory, co nehází a nový zadní plato :o)
12:24:32
01.07.2005
01.07.2005
krasavec,a ta barva! 1305 sedomodra tmava nema chybu.
taky shanis poklicky na meteory??
10:20:53
11.05.2005
11.05.2005
-> COL: pekny dvojnik
08:30:30
11.05.2005
11.05.2005
DuriQ
COL: to s lakosmi poznam
